EVO-STIK Rapid Mitre Fix is a super glue amongst super glues. This cyanoacrylate adhesive with its activator sets in next to no time without compromising bond strength. It will bond a wide variety of materials, including wood, MDF, porcelain, metal, many rubbers and some plastics.
EVO-STIK Rapid Mitre Fix produces excellent results when used on mitre joints for frames and is especially useful for bonding mitres on kitchen cornices and pelmets. EVO-STIK Rapid Mitre Fix produces clean, tight joints in just 10 seconds with an almost invisible glue line. Apply the glue to one side of the joint and spray the activator on the other, bring the two together and count to ten, it’s that simple. A job that would normally take hours with PVA and a range of clamps now only requires a few dabs of glue, a quick spray and around ten seconds.
Pack contains 50g adhesive and 200ml activator
A word of caution: before gluing the intended pieces together, bring the two halves together and check the fit, once glued the bond is very strong and there is no going back.
