Faithfull Kneeler Board Soft Insert
109739
109739
- Protect your knees
- Soft foam pad with tough waterproof base
- Use on hard, rough, cold and damp surfaces
- Provides a comfortable surface to kneel on
- For home, garden and any work situation
- Fitted with handles
- Kneeling area: 450mm x 345mm
Save your knees with this versatile Faithfull Kneeling Board. It has a soft foam pad, attached to a tough plastic waterproof base. The Faithfull kneeler protects your knees from hard, rough, cold and damp surfaces when you need to work in a kneeling position, even for short periods of time. It provides a comfortable surface for use in the home, garden and any work situation. A simple way to look after your knees. Fitted with handles; kneeling area: 450mm x 345mm.
