Faithfull Pin Chuck Set 0 - 2.5mm
- Online exclusive
- A useful tool if you are looking to hold smaller drills
- Suitable for use with pillar drills
- Supplied with three collets 0 - 2.5mm
The Faithfull pin chuck is a useful accessory for holding drills too small to be held by standard capacity drill chucks. Suitable for use with pillar drills, this pin chuck is a great addition to any workshop.
Supplied with three collets of the following sizes: 1 x 0 - 0.75mm (0 - 1/32"). 1 x 0.75 - 1.5mm (1/32 - 1/16"). 1 x 1.5 - 2.5mm (1/16 - 3/32").
EAN Barcode | 5023969232515 |
