FEIN AMM 500 PLUS TOP AS MultiMaster AMPshare Kit 18V (Body Only)
- Outstanding performance for professional users
- Designed for continuous use with high workloads
- AMPshare battery compatibility with Bosch 18V and others
- Brushless motor offers extended runtimes
- Constant electronic speed control with variable speed dial
- Motor with vibration decoupling low vibration and low noise
- Takes all Starlock, Starlock Plus and Starlock Max accessories
- Supplied with:
- 1 x E-Cut long-life saw blade (10 mm)
- 2 x E-Cut long-life saw blades (35 mm)
- 2 x E-Cut long-life saw blades (65 mm)
- 1 x E-Cut carbide Pro saw blade (32 mm)
- 1 x Carbide saw blade (diameter 75 mm)
- 1 x HM rasp (triangular)
- 1 x Scraper blade
- 1 x Sanding plate with holes
- 20 x Sanding sheets (5 of each of grit: 60, 80, 120 & 180)
- 1 x Dust extraction outlet
- Note this is a body only tool supplied without batteries or charger
- Show More
AMPShare is a multi-brand battery system offering the flexibility to switch between tools and brands with compatible batteries. AMPShare batteries make it easy for you to use 18V tools from different brands using the same battery. AMPshare technology is based on the Bosch Professional 18V System, and now includes many leading European brands and is growing. AMPShare batteries are fully compatible with all tools within this multi-brand alliance including Bosch Professional 18V tools and chargers all the way back to 2008.
This FEIN cordless MultiTool now has even more versatility thanks to the AMPshare battery compatibility. MultiTools by name MultiTool by nature. The FEIN AMM 500 PLUS TOP AS can cut, saw, sand, rasp, scrape, polish, grind and more. All performed without being tied to a mains power socket.The cordless freedom and versatility make it one of the best investments you can ever make in your tool kit.
The FEIN AMM 500 PLUS TOP AS takes the complete range of Starlock and Starlock Plus accessories. Starlock and Starlock Plus accessories are available to tackle practically any job. The Starlock system offers great rigidity and 100% transfer of torque. FEIN’s QuickIN tool-free rapid clamping system means tool changes can take less than 3-seconds. An anti-vibration system offers comfortable working even for extended periods. The DC motor has an infinitely variable electronic speed control. The all-metal gearbox can withstand high loads ensuring an outstanding service life.
The FEIN AMM 500 PLUS TOP AS comes in a robust L-Boxx 136 carry case along with:
1 x Scraper blade
Note this is a body only tool supplied without batteries or charger.
