These long-life bi-metal blades are very durable and used for cutting hard and soft wood, laminate, plaster boards, GRP and plastics. The sharp milled HSS teeth have a greater resistance to light contact with brick etc than high carbon steel blades and can last up to three times longer. Cutting cleanly, the tooth ensures a smoke free, no-burn cut especially on material such as MDF. 50mm cut length and 65mm width. The blades are offset so that they can be used to make flush cuts when needed. FEIN 161 blade.
The FEIN Starlock (patented) oscillating multi-tool mounting system overcomes the disadvantages found with previous designs. Starlock sets the new standard in the oscillating multi-tool market. The design greatly improves the transmission of torque from the motor to the tip of the blade. No more wasted power, means faster working, minimised vibration, the potential for longer blades and better results. Looking rather like a crown bottle top, the raised portion of the Starlock snaps into the next generation of multi-tools, making the system truly tool-less.
