Festool 100 Year DOMINO DF500 Q-Plus Jointer 230V
- Unique jointing system using DOMINO® shaped wooden dowels
- Accommodates dowels from 4 x 20mm to 10 x 50mm
- Patented routing principle ensures accurate work with no kickbacks
- Adjustable stops for quick and easy for precise results
- Comfortable operation in any position
- Maximum stability with DOMINO dowels
- Integrates with Festool system accessories for enhanced functionality
- Ideal for panels, racks, frames, drawers, and more
The Festool 100 year DOMINO DF500 Q-Plus Jointer 230V is a remarkable tool that stands out in the woodworking industry for its precision and efficiency. Celebrating a century of innovation, this limited-edition jointer merges the best aspects of round and flat dowels, ensuring robust and invisible joints that enhance both the structural integrity and aesthetic appeal of your woodworking projects. Its patented routing principle guarantees flawless accuracy and eliminates the risk of kickbacks, making it ideal for constructing panels, racks, frames, and drawers. The ergonomic design, featuring a well-balanced and lightweight structure, ensures comfortable operation, whether you are working on large-scale furniture or intricate cabinetry.
One of the standout features of the DF500 is its ability to create rotation-proof joints using DOMINO dowels, which offer unparalleled stability and strength compared to traditional doweling methods. This makes it a must-have for any serious woodworker looking to achieve professional-quality joints with minimal effort. The machine's intuitive adjustment stops facilitate quick and precise settings, saving time and effort while guaranteeing consistent results. Additionally, the DF500 integrates seamlessly with a variety of Festool accessories, enhancing its functionality and providing additional versatility for a wide range of woodworking tasks. These features make the Festool DF500 Q-Plus an excellent choice for customers who value precision, ease of use, and versatility in their projects.
The 'DOMINO' is a unique jointing system using rounded loose tenons to join timber giving very strong accurate and precise joints. Combining exceptional versatility with simple handling for maximum precision, the DOMINO has a patented routing principle with a wide range of adjustment options to make it extremely easy to use. The machine's fence can be adjusted to cut slots centrally in 5 pre-set timber thicknesses and manually adjusted for other thicknesses. The dowels can be placed centrally, offset, in pairs or groups. There are retractable stops for accurate positioning from the edge of the work piece. The jointer fence can be adjusted to 5 pre-set angles and is also infinitely variable between 0 and 90°. There are 6 different sizes of DOMINO available.
Various accessories increase the versatility of the DOMINO: Support bracket which is a simple right angle bracket that attaches to the base of the Domino with two thumb screws, this can be used to add surface area to the face of the Domino to increase stability during use. Trim stop to help align narrow wooden strips between 22 and 70mm centrally, plus it can also be used for mitre cuts. Cross stop, which is used for repeat hole spacing between 100 and 205mm without the need for marking the work. Handrail fence and DF-stop for reducing dowel centre from 37 to 20mm. This can be used to add surface area to the face of the DOMINO to increase stability during use.
Supplied as a DOMINO Q-Plus version complete with: The D5 cutter (for the 5 x 30mm) support bracket and blue 100 Year Festool Systainer SYS3 M187.
