Festool TCT Saw Blades - 160mm x 2.2mm x 20mm
- 160 x 20mm Festool saw blades suitable for the TS55
- Various blade options available, all with 2.2mm kerf
- General purpose medium cutting blade with 28 teeth
- ‘Panther’ faster cutting with less force when rip cutting 12 teeth
- Fine cut, Veneered and coated panels, solid wood, MDF 48 teeth
- Fine cut, aluminium profiles, reinforced plastics 52 teeth
160 x 20mm Festool saw blades suitable for the TS55 plunge saw, all with a 2.2mm kerf. There are a range of blades available; general purpose medium cutting blade with 28 teeth, ‘Panther’ for faster cutting with less force when rip cutting 12 teeth, fine cut, veneered and coated panels, solid wood, MDF 48 teeth, and a fine cut 52 tooth blade for aluminium panels and profiles, hard and fibre reinforced plastics.
