Festool Battery & Duo Charger Energy Set 18V (4 x 5.0Ah)
- Never run out of energy
- Cordless power wherever, whenever
- Zero downtime, always have a charged battery ready
- 4 x 18V 5.0Ah compact Bluetooth enabled batteries
- TCL 6 DUO fast charger; charges 2 batteries at once
- SYS 3 T-LOC Systainer for easy transport and safe storage
- Perfect companion to body only tools
- Compatible with almost all Festool cordless tool
Festool cordless power whenever, wherever you need it and plenty of it. Four 5.0Ah 18V batteries provide enough power to run tools without having to worry about downtime. Even those larger tools that require two batteries.
These batteries are Bluetooth enabled for use with the Festool WorkApp or connection to a CLEANTEC extractor for automatic startup when the cordless tool is switched on (Bluetooth compatible dust extractor required).
The TCL 6 DUO quick-charger, charges two batteries simultaneously. It is suitable for all 10.8V, 14.4V and 18V batteries (except BP-XS for CXS / TXS 10.8 V). The TCL 6 DUO checks the battery's temperature and will not charge a battery that is too hot or cold. Sensors monitor temperature continually throughout the charging process to prolong your battery's life. A separate LED indicator at both charging ports, displays charging progress. You won’t get caught without power for your Festool cordless.
This set represents an ideal addition to the Festool Basic variants or as additional battery packs for the workshop or construction site.
All packed into a SYS 3 T-LOC Systainer for safe storage and easy transport: four 18V 5.0Ah Li-High Power Compact battery packs and a TCL 6 DUO rapid charger.
