Festool DOMINO DF 500 Connector Set KV-SYS D8
104725
From £366.98 £305.82
Low Stock
  • Added potential for the DOMINO DF 500 jointer
  • Produces accurate knockdown joints quickly and easily
  • Enables assembly, disassembly and reassembly of fixtures and furniture
  • Versatile, wide range of panel joints possible
  • Drill template guarantees error-free work
  • Complete kit of parts in T-LOC Systainer
  • See 'Details' for list of contents
Create perfect timber connections
Produce highly accurate and strong cabinets and joinery items simply and quickly with the new Festool DOMINO DF 500 connector set. The new basic structure and furniture connectors are extremely versatile and provide for a very large range of applications. Ideal for use in the workshop, at home or on site, Festool's new DF 500 connector set achieves first class results more quickly than ever before.
Flexible furniture designs
The connectors enable stable yet flexible furniture designs that can be assembled, disassembled and reassembled in another location as well as shelving and much more.
Work quickly and efficiently
All joints are simple to position and machine using the DOMINO DF 500 joining machine. This means the full range of accessories can be utilised, saving you time and effort throughout the process.
One great value package
Ideal for first-time users, the new connector set contains all necessary DOMINO D8 connectors, the associated drilling guide and the cover caps in four different colours. This handy set is very versatile and provides fantastic value for money. The connectors are ideal for centre panel joints, corner panel joints and joints between a series of holes.
This makes the detachable DOMINO basic structure connectors and furniture connectors perfectly suited for a panel thickness of 18mm to 28mm.
This DOMINO KV-SYS-D8 connector system allows you to produce highly accurate and strong knockdown joinery simply and quickly.
The joints are easy to assemble, disassemble and reassemble. All joints are simple and quick to machine using the DOMINO DF 500 jointer; the only additional tool needed is a drill with which to bore a single hole for the tightening the connector. The joints are strong, tight and unobtrusive with a neat cover cap the only clue to its existence.
The system offers increased flexibility for a wide range of applications. It will produce panels with corner ‘L’ joints, centre ‘T’ joints or centre panel joints through a panel and joints between a series of holes. The system makes it significantly easier to assemble a piece of furniture, even working alone. The DOMINO KV-SYS-D8 is suitable for materials with a thickness between 18mm and 28mm.
The DOMINO DF 500 Connector Assortment Systainer offers the best value to get you started with the system.
Supplied in a SYS 1 T-LOC Systainer containing:
70 x DOMINO/DOMINO KV D8 basic structure connector
20 x DOMINO/LR32 KV-LR32 D8 basic structure connector
10 x DOMINO/DOMINO MSV D8 centre panel connector
10 x DOMINO/LR32 MSV-LR32 D8 centre panel connector
50 x Dark brown cover caps
50 x Silver cover caps
50 x White cover caps
50 x Grey cover caps
20 x DOMINO D 8 x 36 mm
1 x BS-KV D15 drill template, 203164
1 x KVB-HW D15 CE hinge location cutter, 203165
1 x Screwdriver
The Festool wooden dowels included are certified by the Pan European Forest Council (PEFC)
5.00 11
