Festool DTS 400 REQ-PLUS Delta Sander
- Delta shaped pad for effective sanding of corners and other awkward spots
- Significant time saving and less reworking
- StickFix hook and loop base, economical use of abrasive
- Plug-It® removable mains cable system
- High speed with small 2.0mm orbit
- Supplied with dust bag and has a 27mm dust extraction outlet
- Pad size: 100 x 150mm Delta
The Delta sanding pad, with its pointed tip, is ideal for sanding into corners. This ability saves time and money by eliminating the need to rework these awkward spots. Weighing only 1.2kg, this sander is comfortable and controllable for single-handed use. Efficient and clean, it is easy to use even for extended periods of time. It is relatively quiet, operates smoothly and has perfect balance. The high speed and small orbit diameter of just 2.0mm leaves an excellent finish. The electronic speed control ensures the sander maintains its speed under load and transfers all 250W of power directly to the work surface. It features Festool’s reliable CLEANTEC extraction connecting system. Connecting it to a vacuum results in virtually zero sanding dust left on the surface you are sanding or in the air. Alternatively, you can use the durable, reusable long-life chip collection bag supplied with the machine. It comes in a Systainer case along with a PROTECTOR, for smooth sanding adjacent to a vertical surface and a long-life dust bag. Pad size: 100 x 150mm Delta.
Corded or Cordless | Corded |
EAN Barcode | 4014549255292 |
Manufacturer Part Number | 201227 |
Model | DTS 400 REQ-PLUS |
Motor Power | 250 W |
Nett Weight | 1.2 kg |
No Load Speed | 6,000 - 12,000 rpm |
Plug Fitted | UK 3 pin plug |
Sound Power Level LwA [Uncertainty K] | 83 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 72 dB(A) [3.0 dB] |
Vibration Sanding [Uncertainty K] | 3.5 m/s² [1.5 m/s²] |
Voltage | 230 V |
