Festool EHL 65 EQ Planer
503830
From £381.98 £318.32
19 Reviews
Low Stock - Ready to dispatch
  • Improved EHL65EQ planer
  • Compact design for single-handed use
  • Planing depth control in 0.1mm steps to max 4mm
  • Unique easy change TCT spiral blade leaves excellent finish
  • Low vibration due to precisely balanced cutter block
  • Dust extraction to either left or right
  • Full wave electronic control soft start
  • Spring-loaded parking foot prevents accidental damage
  • Fitted with overload protection
  • Automatic cut-out when brushes worn
  • Chamfering Vee groove in front platen
  • Supplied with plug-it cable, parallel guide and Supplied in Systainer SYS3 M 187 case
  • Show More
Upgraded version of the EHL 65 Festool Planer with a more compact design and other small improvements to make the machine more refined. The cutting block is fitted with a ground solid carbide blade that gives a shear cutting action across the width of the planer block resulting in a very fine finish. Maximum cutting depth of 4mm (accurately controlled in 0.1mm steps), this machine offers fast waste removal with easily handling. Although using only a single blade, the balance of the cutter block is very fine reducing vibration to a minimum. Changing the blade is simple and no further settings are required. The overall size and layout of the planer make it very easy to use single-handed. Supplied complete with parallel side fence, plug-it cable and Supplied in Systainer SYS3 M 187 case.
Benefits
  • Includes 36 month machine guarantee
  • Full repair, free of charge
  • Replaced in the event of theft
  • Original parts guaranteed
  • 14 day money back
4.90 19
