Festool ES-ETS 125 REQ-Plus Sander with Positioning Aid 230V
- Compact eccentric sander with unique edge sanding attachment
- Sand perfect edges at any angle between 43° and 92°
- Saves hours of work and results in superior finish
The Festool ES-ETS 125 REQ-Plus compact eccentric sander is well balanced and easily manoeuvrable. The sander has a variable speed selector and 250W of power. The 2mm orbit and eccentric action leave an excellent surface finish in a short space of time. The addition of the unique positioning attachment turns the ES-ETS 125 REQ-Plus into a dedicated edge sander. The attachment provides you with a level of control unachievable using any other method. Say goodbye to laborious hours spent hand sanding edges. Using this combination, you can effortlessly sand small or large workpieces, narrow or wide edges, from 5 to 60mm, angled edges from 43° to 92°, external curves and you can sand into an internal corner.
A large surface support ensures complete stability. There is a choice of sanding modes; Hard, the edge is sanded at the pre-set angle. In soft mode the edge sander adapts precisely to the surface to be sanded, for a gentler action meaning neither paint nor filler is sanded through.
The ES-ETS 125 REQ-Plus comes with the AH-ES-ETS/ETSC positioning aid, a StickFix sanding pad (soft-HT), long-life chip collection bag and 4m plug it-power cable in a Systainer SYS3 M 337.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
Cable Length | 4 m |
Corded or Cordless | Corded |
Dust Collection | Dust Bag Supplied |
Dust Extraction | 27 mm Outlet |
EAN Barcode | 4014549371992 |
Manufacturer Part Number | 576680 |
Model | ES-ETS 125 REQ-Plus |
Motor Power | 250 W |
Nett Weight | 2.0 kg |
No Load Speed | 6,000 - 12,000 rpm |
Orbit Diameter | 2.0 mm |
Pad Size | 125 mm |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 84 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 73 dB(A) [3.0 dB] |
Vibration Sanding [Uncertainty K] | 3.5 m/s² [2.0 m/s²] |
Voltage | 230 V |
