Festool KAPEX KA-UG-KS 60 Trimming Attachments for UG-KS 60
- Fits the Festool KS 60 mitre saw and base frame combination
- Quick and easy setup
- Each one extends up to 2.4m
- Great support for perfect working results
- Clear measurement scales
- End stops for accurate repeat cuts
The trimming attachments (or material support extensions) attach to the side of the UG-KS 60 base frame and KS 60 compound mitre saw combination. They are easy to mount and each has an adjustable support leg for levelling with the saw table. Each extension is 1,480mm long with a metric scale and adjustable length stop for repeat cuts. Their outstanding feature is a pullout telescopic extension, which allows for a full 2,400mm of support. The pullouts have clear measurement scales and end stops. These attachments make working with full-length boards a breeze, plus they are safe, convenient and accurate.
