Festool MFT Perforated Top for KA 65 Edgebander
- With cut-outs for stationary use of the edgebander in the MFT/3
- Used with Adaptor Plate AP-KA 65
- For small batches, straight and free form edges plus inclined angles
The CONTURO can be used as a stationary edgebander in either the Festool MFT/3 or in a bench built by the user. If the MFT/3 is to be used, simply replace the perforated board with the Insert Panel. The recess in the panel is the correct size to install the Adaptor Plate and the threaded bushes for the guide plates. If you are working with a bench you have built yourself, the tabletop will require a recess and a cut-out so that the Adaptor Plate can be screwed in flush.
EAN Barcode | 4014549217641 |
Manufacturer Part Number | 500366 |
