Festool MINI Systainer T-LOC With M/P Insert
- Transparent lid allows you to view contents without opening
- Moulded insert with 8 compartments
- Ideal for small parts, fixings etc.
- Contents stored safely and securely
- Robust ABS construction
- Protects against dust, dirt, splashes and impacts
- Mini T-LOC Systainers stack and lock together
- Overall size 265 x 171 x 70mm
This Mini Systainer has a transparent lid allowing you to view the contents without opening the case. An 8-compartment moulded insert keeps small parts separated. The compartment sizes are as follows (all measurements approximate): depth 45mm, 6 compartments 50mm square, one compartment 100mm square and one compartment 150mm x 50mm.
The arrangement makes this Systainer ideal for small parts or fixings. The design protects the contents against water splashes, dust, dirt and impacts. The T-LOC latch allows you to stack and lock multiple cases together, for easy carrying. You can also open an individual case while in the stack.
The Mini Systainer is 265mm wide x 171mm deep front to back and 70mm high.
N.B. Cannot be connected to T-LOC SYS 1, SYS 2, SYS 3, SYS 4, SYS 5 or SORTAINER.
