Festool OF 1010REBQ-Plus Router with LED Light (1/4") 230V
- Extremely versatile and extremely precise
- Rechargeable LED light ring provides shadow free lighting
- Supplied with the updated, easily adjustable parallel side fence for quick and precise alignment
- Depth adjustment to within 0.1 mm
- Easy one-handed operation
- Supplied with 1/4" and 8mm collet
Axminster Professional Twist & Fix 100mm Nylon Abrasive Wheel - FineSpecial Price £11.42 £9.52 was £14.28 £11.90 Save £2.86 £2.38
Festool OF1010 Router Accessory SetFrom £244.98 £204.15
Festool Parallel Fence for OF1010/MFK700 RouterFrom £62.28 £51.90
For power and accuracy, for easier, safer routing the Festool OF 1010 REBQ-Plus with LED Light, is in a class of its own. In a nutshell it is extremely versatile, excellently precise and very easy to handle.
The routing depth can be adjusted to the nearest tenth of a millimetre in seconds. The double-sided column clamp makes the router extremely torsionally rigid, guaranteeing perfect routing results.
With the rechargeable LED light ring around the working area, you can see the workpiece clearly and without any shadows. This is essential for achieving high accuracy in routing. This smart design lets you closely see the router cutter to improve your accuracy further.
This router allows easy one handed operation either with the Festool guide rail system or freehand.
Festool's Plug-It system with its detachable power cable enables the fast swapping of Festool tools or easy cable replacement. The new style Festool parallel side fence is easily adjustable for quick and precise alignment, as the central clamp features a fine adjuster and adjustable guidance jaws, free of any tools.
Supplied with 8mm and 1/4" collets, side fence, guide rail adapter, open ended spanner all packed in a Systainer SYS3 M 237 case.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Replaced in the event of theft
- Original parts guaranteed
- 14 day money back
Cable Length | 4 m |
Collets Supplied | 1/4" and 8 mm |
Corded or Cordless | Corded |
Cutter Speed | 9,500 - 23,000 rpm |
EAN Barcode | 4014549436875 |
Fine Height Adjuster | Standard Equipment |
Manufacturer Part Number | 578004 |
Model | OF 1010 REBQ-Plus |
Motor Power | 1,010 W |
Nett Weight | 3.2kg |
Plug Fitted | UK 3 pin plug |
Plunge Stroke | 55 mm |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 103 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 92 dB(A) [3.0 dB] |
Spindle Lock | Standard Feature |
Vibration Cutting Wood [Uncertainty K] | 2.0 m/s² 5.5 m/s² |
Voltage | 230 V |
