Festool OSC 18 Li E-Basic VECTURO Muli-Tool 18V (Body Only)
- E-TEC motor with electronic speed control
- Long runtimes with plenty of power
- For cutting, sanding, polishing a wide variety of materials
- StarLock Max tool-less, quick blade change
- Cordless freedom, power and performance
- Includes SYSTAINER SYS 2 T-LOC case and universal saw blade
- Body only machine supplied without battery, charger or interface for depth stop
Work fast and with maximised precision
Achieve accurate results in sanding, cutting and polishing tasks with the OSC. This innovative VECURO system is the answer to demanding tasks that require efficiency and the power to last all day.
Power and efficiency, combined
The brushless EC-TEC motor features electronic speed control, resulting in producing powerful, fast cuts in a variety of materials. Whilst power is at the forefront, the motor consumes minimal energy, providing an excellent battery life. Plus, the benefit of a brushless motor is that it results in less friction, therefore minimising maintenance requirements.
Make quick changes
Saving you time with its innovative Quick-Change System, the OSC allows for rapid and hassle-free tool changes. Securely attach and detach accessories with simply a click thanks to the Starlock Max Tool Holder. Enhance your productivity with this seamless feature, without the need for manual adjustments or additional equipment. It’s a real game-changer.
Comfortable working
When working long hours, you need to turn to a tool that is comfortable and gets the job done smoothly. The OSC has noise and vibration dampening for this exact reason. The anti-vibration system isolates the motor and slimline housing, with an ergonomic rubber grip, resulting in comfortable and controlled handling for the user, for extended amounts of time.
Cordless freedom
Part of the 18V family, the OSC sits nicely within the pack of powerful tools, that are proven to make tasks run more easily. Wave goodbye to the limitations of entangled cords and embrace the flexibility that this range provides. Don’t worry, these tools bring the power, delivering as much endurance and run-time as a manual tool. Simply interchange tools within the 18V battery system. Festool won’t be beaten on innovation so whatever your project requires; this comprehensive range has got the tool for it.
Dust extraction
As is the case with Festool 18V tools, dust extraction solutions are always considered. Enhance your safety with minimal interference from dust particles. The OSC-AV dust extraction adaptor lets you connect directly to a vacuum extractor for clean, dust free working.
MyFestool
For your added support, Festool offers a comprehensive service plan once you register your tool. Enjoy the following benefits with the Warranty all-inclusive:
- Free repairs for three years
- Fast resolution directly from Festool
- Replaced in the event of theft
Festool BiM Universal Multi-Tool Blades 65mm (Pkt 5)From £93.18 £77.65
The Festool OSC 18 LI E-Basic VECTURO Multi-Tool is a body only machine. At its heart is a brushless EC-TEC motor, which generates plenty of power at the same time drawing relatively little energy from the battery. As a result, you get far more work out of a fully charged battery and extended runtimes.
The VECTURO features variable electronic speed control ensuring fast cuts in a wide variety of materials. The vibration isolation between the motor and slimline housing plus an ergonomic rubber comfort grip offers both comfort and control. The Festool OSC 18 LI 3.1 E-Set VECTURO gives you cordless freedom, greater precision and unbeatable performance. The StarLock Max blade changing system is quick and easy, without the need for tools: simply clip-in, lock and go. Supplied in a SYSTAINER SYS 2 T-LOC carry case, along with a USB 78/32/Bi/OSC universal saw blade.
This is a body only machine without battery or charger. Please note, this does not come with an interface for a depth stop.
Benefits
- Includes 36 month machine guarantee
- Full repair, free of charge
- Original parts guaranteed
- 14 day money back
Batteries Included | Body Only Tool |
Battery Type | Li-ion |
Battery Voltage | 18 V |
Corded or Cordless | Cordless |
EAN Barcode | 4014549315842 |
Manufacturer Part Number | 574848 |
Model | OSC 18 Li E-Basic |
Nett Weight | 1.6 kg |
Oscillation Rate | 10,000 - 19,500 /min |
Oscillation Stroke | 2 x 2.0° |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 94 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 83 dB(A) [3.0 dB] |
Vibration Plunge Saw Blade [Uncertainty K] | 7.0 m/s² [1.5 m/s²] |
Vibration Segment Saw [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
