Festool PSBC 420 Li Cordless Jigsaw 18V (Body Only)
- Cordless uses high power with Festool Li-Ion battery technology
- Accurate and precise vertical cuts with blade guide system
- Hammer guide within the blade guide system
- Quick blade change, changeable baseplate
- Switch worked either right or left of body
- Part of the Festool 18V Li-Ion family
- Supplied as body only without battery and charger
- Supplied with 2 blades and splinter guard
- Systainer 2 T-LOC storage case
This cordless jigsaw has a powerful cutting stroke driven from the Festool EC-TEC brushless motor. A long runtime is guaranteed when run from Festool's 18V high capacity Li-Ion battery and Festool technology. The end result is a seriously good jigsaw.
This PSBC bow grip jigsaw is supplied as the Basic version and as body only (without battery or charger). It comes with two jigsaw blades and a splinter guard in a T-Loc Systainer case.
The bow handle version jigsaw shares exactly the same features as its corded cousins. The blade is guided in three ways with a new lower guide that can be adjusted to 'kiss' the blade. A powerful hammer guide contained within the body of the machine ensures accuracy. Combined with a choice of four pendulum stroke actions and speed selection, you can be assured of a smooth, precise cutting action, designed to work hard in a range of materials with the right choice of blade. It is compact in design and one of the lightest on the market at only 2.3kg. An adjustable strobe light is also a great feature. Effective dust extraction draws dust away from the cutline via connection to a dust extractor from the outlet in the base. The on/off switching can be worked from either the bow handle or either side of the body for dual use.
Supplied with a standard removable base that can be replaced with a choice of either a tilting 0-45° angled base or a base adaptor that allows you to connect guide rails or circular guide, available as optional extras. A quick lock feature ensures no tools are required for base or blade changing. Part of the Festool 18V family.
3 year Service All-Inclusive warranty available on registration.
