Festool SCA 16 Rapid Charger 230V
109783
From £131.98 £109.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Rapid charger for Festool 10.8 V, 14.4 V and 18 V classes
  • AIRSTREAM cooling function helps regulate temperature and charging efficiency
  • LED function to save time, showing remaining battery life and charge status
  • Store efficiently, the cord holder on the housing and device for wall mounting
There is no faster way to charge your batteries. The Festool SCA 16 Rapid Charger 230V is a powerful charging solution designed to efficiently recharge Festool's battery packs. With its advanced technology and intelligent features, this charger ensures swift and reliable charging performance. The SCA 16 Rapid Charger is specifically designed to be compatible with Festool's 18V battery packs, 10.8V and 14.4V voltage classes, allowing users to quickly restore power to their cordless tools. Equipped with an integrated AIRSTREAM cooling function, maintaining the ideal temperature during charging, enhancing both safety and charging efficiency. Monitoring and adjusting the charging process helps to optimise battery life and prevent overcharging.
The LED function shows the remaining battery life and status of charge.
Ideal for extremely fast charging in conjunction with AIRSTREAM battery packs (4.0 Ah, 5.0 Ah, 5.2 Ah, 6.2 Ah and 8.0 Ah)
