Festool SYSLITE DUO Work Light DUO-Plus
- Illuminates work areas evenly
- Unique LED configuration for 180° scattering angle
- Homogeneous lighting similar colour to daylight
- Extremely sturdy and durable, housing protection class: IP 55
- LED service life of 10,000 hours
- 4.9m cable length, integral cord holder
- Supplied in a Systainer SYS3 M 237
When you can see what you’re doing, the work is certainly easier and its quality naturally improved. The Festool SYSLITE DUO-PLUS (230V) uses 80 LED’s to light up the working area with a power of 8,000 lumens. The 180° scattering angle literally floods the area with homogeneous light similar to daylight in quality. The SYSLITE DUO-PLUS will illuminate an entire room without patchy light and dark areas. The LED's have a working life of over 10,000 hours - more than enough for a few arctic winters. The case is dust and water-resistant. It is very robust with shock-proof corners, able to withstand drops and impact (safety class IP 55). The 4.8m of cable allows for a large operating range and neatly stores away in the cord holder when not in use. Weight 3.4 kg.
Cable Length | 4.8 m |
Corded or Cordless | Corded |
MPN | 769965 |
Voltage | 230 V |
