Festool SYSLITE KAL II Compact Work Light
- Transforms dark areas into work areas
- Bright even light, recreating daylight conditions
- 12 high performance LEDs, 170° scatter angle
- Compact, robust, impact resistant and shatterproof
- Head can be angled, also serves as a reflector to scatter light evenly
- Adaptor with magnetic spherical head with flat disc for easy positioning
- Powered by 230V mains, integral 7.2V Lithium-ion battery
- Festool battery 12-18V or used with the car charge adaptor
- Magnetic spherical head optional accessory
- Supplied with hanging hook, 230V adaptor, car charger and transport bag
The SYSLITE II transforms dark areas into work areas. The bright, even light comes from 12 high powered LEDs creating daylight conditions, giving a scattering angle of 170°. Compact and robust it is impact resistant and shatterproof. The head can be angled to shine exactly where it is needed. Sitting securely, it can be hung on the shatterproof universal hook, used as a stationary lamp or fitted to the magnetic spherical head with flat disc. It also has a standard tripod (1/4") fitting. Versatile, it can be powered by 230V mains supply, by the integral 7.2V Lithium-ion battery (up to four hours), by attaching a Festool battery 12-18V (up to 8 hours) or used with the car charge adaptor. Size 150 x 100 x 80mm, weight 670g. Magnetic spherical head optional accessory. Supplied with integral 7.2V battery, charger adapter 230V, car charger and transport bag.
