Festool TS 55-FEBQ Plus Plunge Saw
- Accurate plunge cutting saw for splinter free cuts
- 1.8mm thin kerf blade for fast cutting
- Fully compatible with Festool FS guide rail system
Festool’s TS 55 saws have a reputation for absolute precision cuts, maximum power and extreme durability. This latest incarnation is no exception. The TS 55-FEBQ takes a 1.8mm kerf blade. The narrow kerf means it removes much less material, allowing the TS 55-FEBQ to cut at up to twice the speed of previous models. The new generation of cutting blades guarantees perfect cutting quality with maximum cutting performance.
A detachable splinter guard in front of the blade, gives a virtually splinter-free finish on both sides of the workpiece. Behind the blade a guide wedge acts as a riving knife and aids positioning the saw in an existing cut. The angle adjustment from -1° to 47° allows a slight undercut for perfect butt joints. In addition, the cut line remains the same no matter what the cutting angle. With the TS 55-FEBQ maximum cutting performance meets perfect cutting quality.
Optional guide rails, a wide variety of thin 1.8mm kerf saw blades and connection to an extraction system, form a first-class sawing system.
Supplied with 42 tooth thin kerf blade and Systainer SYS3 M 337 carry case.
N.B 230V version is known as model TS 55-FEBQ. 110V version is known as TS 55-FEQ.
