FISCH M2 HSS Professional Brad Point Drill Bits
AX890611
AX890611
- Fast clearing, premium brad point drill bit
- Made from high grade M2 steel
- Used in all types of wood, laminated boards, MDF and acrylic glass
- Made in Austria
Show more
Show less
FISCH have produced a fast clearing premium drill bit made from high grade M2 steel. The unique four flute design with a brad point (lip and spur) tip ensures fast and easy cutting of the wood before the hole is drilled. The perfect drilling geometry not only makes holes more accurate, but also means holes can be drilled faster saving you time and, if a tradesman, money. They can be used in all types of wood, laminated boards, MDF and acrylic glass. Made in Austria.
#AxminsterTools
