FISCH SP Brad Point Drill Bits
- SP Brad Point (AKA lip and spur) bits, precisely ground and sharpened
- Exact geometry for fast accurate drilling, made in Austria
- Available in a range of both metric and imperial sizes
Axminster Workshop Dowel Drill Stop Collar Set 3 (6, 8 & 10mm)From £2.48 £2.07
Axminster Workshop 13 Piece High Speed Steel Ground Drill Bit SetFrom £7.28 £6.07
These FISCH SP Brad Point or lip and spur bits are precisely ground and sharpened in Austria with the exact geometry needed for fast accurate drilling. Available in a range of both metric and imperial sizes suiting all types of timber.
N.B 3mm - 9mm have same shank as diameter, 10mm - 18mm have a 10mm shank, 20mm has a 13mm shank. 1/8", 3/16" and 1/4" have same shank as diameter.
