Fiskars Norden N10 Chopping Axe 1.2kg (2.6 lb)
112316
From ÂŁ57.54 ÂŁ47.95
1 Review
Low Stock - Ready to dispatch
The Fiskars Norden N10 Chopping Axe has a 35.5cm hickory wood handle that makes it ideal for easy one-handed use. The handle also incorporates virtually unbreakable Fibercomp™ overstrike protection. Carbon steel blade with a precision ground, ultra-sharp cutting edge that stays sharp. The anti-friction coating prevents the blade from getting stuck and protects against rust and dirt. A great general tool for chopping and kindling tasks, and small construction projects around the house. Protective blade cover included. Made in Finland.
Specification:
Weight: 1.2kg (2.6 lb)
Length: 355mm
5.00 1
