Fiskars Norden N7 Chopping Axe 800g (1.7 lb)
112317
From ÂŁ54.85 ÂŁ45.71
1 Review
Low Stock - Ready to dispatch
The Fiskars Norden N7 Chopping Axe has a small, compact design. Ideal for limbing, chopping and kindling. Fitted with a high-quality hickory wood handle with virtually unbreakable FiberComp™ overstrike protection. Carbon steel blade with a precision ground, ultra-sharp cutting edge that stays sharp. The antifriction coating prevents the blade from getting stuck and protects against rust and dirt. The perfect companion for camping, hiking and other outdoor activities. Protective blade cover included. Made in Finland.
Specification:
Length: 172mm
Weight: 800g (1.7 lb)
5.00 1
