Fiskars WoodXpert™ XA23 Brush Hook
112298
From £62.03 £51.69
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
The Fiskars WoodXpert™ XA23 Brush Hook is ideal for cutting larger branches from trees/logs and clearing saplings and brush. The ultra light and durable FiberComp™ handle minimises fatigue and make the tool virtually unbreakable. Its longer shaft provides better swing speeds and the power of a double handed grip. The optimal anti-shock surface structure ensures a comfortable firm grip. The hooked end of the handle prevents slipping. Specifications:
Length: 943mm.
Weight: 993g.
