Fiskars Chopping Axe
Fiskars X Series Chopping Axes serve all manner of woodwork, chopping, carpentry and pruning. The Universal Chopping Axes have thin, wide edged blades to ensure a clean, easy cut in fresh, resinous wood, like spruce or pine. The range delivers a beautiful package of minimalist design and sharp-edged functionality with the right fit for all wood preparation tasks. Pick your size according to the task at hand. The ultra-light and durable FiberCompâ„¢; handle minimises fatigue and makes the axe virtually unbreakable. This chopping axe features the right balance between the head and shaft for safe, comfortable and efficient use. The axe also has an optimal anti-shock structure, while the hooked end of the handle prevents the axe from slipping. New 25 Year Warranty. Fiskars offer the best in class, in Europe, for premium axes. To speed up the claim process, your receipt acts as a certificate, upon registering online. Registration also allows you to access a guide on use, tips & tricks online.
