Flexcut 11 Piece Palm Tool SK Travel Package
- Flexcut 10 blade Palm Tool SK Travel Set
- Excellent for carvers while travelling
- Palm handle with 10 interchangeable blades
- Includes pre-printed wooden blank
- Flexcut KN13 Detail Knife
- Features edge-holding steel found on other Flexcut tools
- Comfortable, well-shaped carved handle
- Flexcut Knife Strop
- Excellent for quickly restoring your edges
- Complete with Flexcut Gold Polishing Compound
Package comprises the Flexcut 10 blade Palm Tool SK Travel Set, Flexcut KN13 Detail Knife and the Flexcut Knife Strop
This set is an excellent idea for the carver who wants to practice his or her craft while on holiday, travelling or just at odd moments throughout the day. The sets consist of a palm handle, and four interchangeable blades, a pre-printed wooden blank and instruction. All packed in a good quality tool roll. The 10 blades included are as follows: 3 sweep x 3/8"(9mm) and 5/8"(16mm), 5 sweep x 9/16"(14mm), 6 sweep x 5/16"(8mm), 9 sweep x 1/16"(1.5mm), 11 sweep x 1/8"(3mm) and 1/4"(6mm) gouges, 45° x 1mm micro parting tool, 70° x 1/4"(6mm) vee tool and a 1 x 1/4"(6mm) chisel.
This knife shares the same edge-holding qualities as the Flexcut gouges and chisels. The KN13 Detail Knife has a very fine point for making the very narrow cuts associated with detailing. Its straight 38mm blade can accommodate larger stock removal if needed. The comfortable carved handle allows for long periods of carving without fatigue.
Flexcut Knife Strop
Although Flexcut call this a knife strop, you can use it for other carving and edge tools just as effectively. Polishing the edge on the strop, gives it an extra degree of sharpness. Regular stropping of a blade means less honing which saves time and effort. It comes with a block of Flexcut Gold Polishing Compound. Size approx 200 x 50mm.
