Flexcut Double Bevel Sloyd Hook Knife
104594
From £114.68 £95.57
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Double edge curved blade, 19mm radius
  • For carving and hollowing spoons, bowls etc
  • High carbon steel blade gives superior edge
  • Through tang design for extra strength
  • Smooth cherry wood handle with brass ferrule
  • Made in USA
The Double Bevel Flexcut Hook Knife is a must in any spoon carver’s armoury.
The 19mm radius of the curved blade allows you to carve hollows in spoons, bowls, ladles etc. The double edge gives you the option of working to the left or right, push or pull, whichever way cuts the timber most effectively. The blade is made of high-carbon steel which gives exceptional edge retention. For added strength, the knife features a brass ferrule and a through tang. The smooth cherry wood handle is comfortable in the hand. The overall length of this knife is 195mm, with a blade radius of 19mm.
As with all carving tools, regular honing makes for better results. Made in USA.
