Flexcut KN17 Mini Drawknife
- Designed for hard-to-reach areas
- Flexible shank allows the cutting angle to be changed easily
This miniature drawknife is designed for hard-to-reach areas, where a pulling action is more conducive to efficient stock removal. The flexible shank allows the cutting angle to be changed easily for contoured cuts.
EAN Barcode | 651646500173 |
