Flexcut KN35 Fine Detail Knife
- Features edge-holding steel found on other Flexcut tools
- Comfortable handle for long periods of use
These knives are made with the same edge-holding steel as the Flexcut gouges and chisels. Designed for making fine detail cuts, the user also has the ability to "choke up" on the blade for even more precise cuts. The handle shape holds like a pencil or conventional knife.
EAN Barcode | 651646500357 |
Model | KN35 |
