The Flexcut Pro Series 1" Chip Carving Knife is a high-quality tool designed for precision and control in chip carving. It features a full flat grind, deep angle chip carving blade made from precision heat-treated 1095 steel, polished to a brilliant mirror finish.
This knife excels at making controlled plunge cuts needed for many chip carving styles. The deep angle of the blade, shorter choil length, and narrow tapered detail tip provide the leverage and accuracy needed for the most detailed chip carving cuts. This knife is made in the USA. It is a valuable addition to any carving kit, offering both durability and precision for intricate carving tasks.
The Flexcut Pro Series range has been crafted with insights from customer feedback and professional carvers, these knives are a game-changer for any carving kit. With increased clearance between the choil and heel, you will enjoy a more consistent stropping experience, keeping blades sharper for longer.
The handles are designed with flat sidewalls, bold facets, and curves in all the right places, this premium un-varnished cherry wood handle is a joy to hold. The area under the blade has been streamlined to eliminate interference on tight cuts, and an index finger swell has been added over the spine for extra power and superior control.
