Fuji Spray T-Model Air Caps
- Sizes from 0.8mm to 2.0mm; for T70 & T75 Series spray guns only
- The smallest is suitable for inks, shading and mist coats
- The largest is great for spraying large surfaces or textured coatings
Finest 0.8mm (.030") size Aircap Set for finest atomisation. Suitable for inks, shading, mist coats and spray tanning.
Fine 1mm (.039") size Aircap Set for finer atomisation. Suitable for most water-based lacquers and shading.
Standard 1.5mm (.060") is installed in all Xpc spray guns. Aircap Set is perfect for most fine finishing.
High output 1.8mm (.070") Aircap Set for faster coverage of large areas with any type of paint.
High output 2.0mm (.090"). Great for spraying large surfaces such as walls with emulsions. Expect some slight texture.
For T70 & T75 Series spray guns only - does not fit older Fuji spray guns.
Model | T-Series |
