Fuji Spray 2030 Maintenance Kit for Gravity Feed Guns - (Ptk 5)
950545
950545
- This kit contains the pressure tubes with check valves installed
- Keeps your gun in tip top working condition
- For the 400cc Xpc Gravity Gun
- Can also be used with the M model gravity gun
Show more
Show less
This kit contains the pressure tubes with check valves installed, and cup gaskets for the FUJI Xpc 400cc Gravity Feed Spray Gun. The check valves cannot be taken apart, they can be soaked in thinners to free any blockage. This kit contains the wearing parts of the gun and will keep your gun working properly. This kit can also be used with the M model gravity guns.
2 Year Warranty
EAN Barcode | 612850020307 |
Model | 2030 |
