The 3M PPS™ Series 2.0 H/O Midi Pressure Cup 26121 comprises a pressurised hard cup, collar/shroud assembly, and hose. The pressure cup is the base on which to build your own 3M PPS™ system. The 3M PPS™ 2.0 H/O Midi Pressure Cup 26121 requires a suitable adapter to fit your spray gun. Order liners, lids, and caps separately.
The 3M PPS™ system is a cleaner, faster system, safe from outside contamination and offers considerable time and solvent savings in regards to gun cleaning. The 3M PPS™ system consists of a reusable plastic cup with disposable liners and lids. With the 3M PPS™ system fitted to your spray gun, turning your Fuji turbine on, pressurises the H/O cup forcing the liner on the inside to start to collapse. This will push the paint or finish in the liner into the spray gun no matter the orientation of the spray gun.
Note that this is ONLY for HVLP spray guns, NOT for compressor guns.
The 3M PPS™ 2.0 H/O MidiPressure Cup 26121 requires a suitable adaptor to fit your spray gun.
