GLOFORCE™ EYE-LIGHT™ Pro
108476
From £89.98 £74.98
Low Stock
  • Extremely versatile, ultra bright, rechargeable
  • The worklight we’ve always dreamed about
  • Stand it, Stick it, Bend it, Wear it
The GLOFORCE™ EYE-LIGHT™ Plus is an amazingly versatile, 1,000 lumen rechargeable 10W LED floodlight. It comes with a steel base and a 450mm flexible gooseneck with a strong magnetic foot. Giving you plenty of ‘reach’. Use the flexible rubber gooseneck to position the EYE-LIGHT™ exactly where you need it.
On the steel base it’s a stand alone floodlight. Taken off the base, the magnetic foot can be attached to any steel surface, such as a lathe headstock, drill press, milling machine. The rubber foot will not damage paintwork if used when working on a vehicle.
The flexible gooseneck can be hooked over or wrapped around items. You can even wear it wrapped around your neck leaving your hands free. It is IP65 rated weatherproof and IK10 rated shockproof for use indoors or outdoors.
Using the most advanced LED chips, the 80mm diameter GLOFORCE™ EYE-LIGHT™ outperforms many larger floodlights. The rear features a four stage LED battery indicator. It has two 1/4” UNC mounting points, one on the back and one on the side. With a beam angle of 120 and range of 50m, EYE-LIGHT™ will brighten even the darkest working area. It can be used as an USB power bank for recharging your phone or tablet. The light even has a built-in SOS Flash mode, just in case. On medium beam expect 7 hours run time, on full beam at least 3.5 hours. Supplied with USB charger lead.
Stand it, Stick it, Bend it, Wear it.
Warranty 1 Year Warranty
4.8 5
