Heavy Duty Polishing Kit for Brass, Copper & Non-Ferrous Metals
- Use with a drill, flexible shaft or bench grinder fitted with a taper spindle
- Produce a mirror finish on aluminium, brass, copper and similar metals
- 2 x mops, 2 x compounds, 1 x pigtail arbor with 6mm shank
Used with a power drill or flexible shaft, this kit provides all you need to produce a mirror finish on aluminium, brass, copper and similar soft metals. It only takes two easy steps, initially with the 100mm, two section stiched mop and brown compound, then followed by the 100mm x 25mm loose leaf, soft mop and blue compound. The kit also includes a pigtail arbor with a 6mm shank with which to mount the mops in a drill chuck.
