Heavy Duty Polishing Kit for Plastic, Fibreglass & Bakelite
- Use with a drill, flexible shaft or bench grinder fitted with a taper spindle
- Produce a high gloss finish on plastic, acrylics, fibreglass and Bakelite
- 2 x mops, 2 x compounds, 1 x pigtail arbor with 6mm shank
Used with a power drill or flexible shaft, this kit provides all you need to produce a high gloss finish on plastic, acrylics, fibreglass and Bakelite. It only takes two easy steps, initially with the 100mm, 2 section stitched mop and brown compond, followed by the 100mm x 25mm soft loose leaf mop and buff compound. The kit also includes a pigtail arbor with a 6mm shank with which to mount the mops in a drill chuck.
