Hermes RB 377 YX Abrasive Belts 150 x 1,090mm
AX19832
AX19832
- Polyester/cotton cloth backed aluminium oxide abrasive
- High stock removal rates in the coarse grit range
- Consistent surface quality in the fine grit range
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
Show more
Show less
150 x 1,090mm (6" x 43") Sanding Belts, 60, 80, and 100 Grit. The polyester/cotton back combined with the resin bonded aluminium oxide grain mix produces a high stock removal with coarse grits, plus a consistent surface quality with fine grits. Smooth running and long lasting, perfect for abrading metals and sanding seasoned woods.
Abrasive Backing | Cloth |
Abrasive Belt Length | 1,090 mm |
Abrasive Belt Width | 150 mm |
Abrasive Type | RB 377 YX |
