Being one of the UK's leading abrasive suppliers, Hermes have developed a special multi-hole abrasive for use with 1/3rd sheet sanders, this high quality VC 151 abrasive has small holes punched over its whole area to ensure that the extraction air flow can act effectively and that there is no build-up on the abrasive grain to give a much higher level of performance with a swirl free finish. No need to worry how many extraction holes your sander has or lining them up, these can be used on all 1/3rd sheet sanders saving time and money as well as helping to eliminate dust for a cleaner and safer working environment. The abrasive will give high performance and quality with high stock removal and is made from aluminium oxide, resin bonded with a long life coating and put onto a special flexible tear proof C paper backing making it suitable for all finishing. Available in packs of 10. Size: 93 x 184mm.
