Hermes BW 110 Resin Bonded Abrasive Roll 90mm x 10m
AX21074
AX21074
- Aluminium oxide abrasive on heavy E-weight paper backing
- Semi-open coating, anti-static resin bonded reduces clogging
- Economical sanding for excellent results on all types of wood
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
Show more
Show less
Aluminium oxide resin bonded abrasive on a heavy weight paper for machine and hand sanding of wood, wood based products, paints and varnishes. The heavyweight paper reduces breakage at the securing point on orbital sanders.
Abrasive Backing | Paper |
Abrasive Roll Length | 10 m |
Abrasive Roll Width | 90 mm |
Abrasive Type | BW 110 |
