Hermes HSB Abrasive Belts 75 x 480mm
AX20880
AX20880
- Aluminium oxide abrasive on heavy duty X-cloth backing
- Resin bonded, closed coating for long life
- Excellent results on wood, metal, lacquer and composites
Axminster Workshop Abrasive Belt Cleaner - Large (300 x 50 x 50mm)From £30.28 £25.23
Axminster Workshop Abrasive Belt Cleaner - Standard (210 x 40 x 40)From £13.68 £11.40
Show more
Show less
High quality, heavy duty abrasive belt. Aluminium oxide coated resin bonded on a cloth backing giving a constant surface coating for the best possible finish. Suitable for wood, metal, lacquer and composite. Very strong secure belt join for long life.
Size 75 x 480mm to fit many makes of belt sanders.
Abrasive Backing | Cloth |
Abrasive Belt Length | 480 mm |
Abrasive Belt Width | 75 mm |
Abrasive Type | HSB |
