N.B. To buy this product you must be aged 18 years or over. We will verify your age before despatching the order and this might involve us contacting you for proof of age. The product must also be delivered to, or collected by, a person 18 years or over.
A perfect cross between a knife and a chisel
Blade length: 70mm, thickness 3mm
High carbon Japanese steel , double bevelled edges
This is a perfect cross between a knife and a chisel. The Chisel Knife is a robust knife with double bevelled edges. The 70mm long blade is made of 3mm thick high carbon Japanese steel hardened to 58-60 HRC. The double bevel cutting edges receive a final honing on a leather strop before leaving the factory. The handle and sheath are of extra durable PP plastic. It features a unique method for attaching the sheath around a button on your work clothes, which means it does not loosen, but is easy to remove. The sheath fits just as well on your belt as on your buttons. If your belt is thick, cut away the small pin on the cover.
N.B. By purchasing any knife, you are confirming that you are AGED 18 or over.
