With this versatile rotary attachment, you can enhance the capability of your i2R CNC Router even further, with woodturning style machining. With the 4th Axis Rotary Kit, you can handle projects such as: intricate engraving on round surfaces, 3D carvings on cylindrical objects, custom furniture legs, and more.
It is compatible with any 4-axis ready i2R machine and will integrate easily with your existing CNC setup, thanks to its user-friendly intuitive design. It’s also compatible with V Carve Pro software for 3-dimensional work. With a chuck capacity of 80mm and a chuck diameter of 100mm, it accommodates a range of cylindrical workpieces. The centre through hole has a diameter of 13mm, and the overall height is 140mm. It is easy to install onto your CNC machine, and you can quickly switch between flat and rotary machining – making this a fantastic accessory for your i2R CNC Router.
The i2R 4th Axis Rotary Kit enhances CNC machining versatility, allowing precise and intricate automated work on cylindrical objects. Whether you’re an enthusiast or a professional, this accessory opens up new creative possibilities!
