King Japanese Nagura Stone
- Keep water stones in peak cutting condition, cleans glazed surfaces
- Use to create slurry prior to honing
- Equivalent of 8,000 gold stone, size: 70 x 20 x 23mm
Used for cleaning a glazed surface or creating a slurry prior to honing on finer stones, thereby speeding up the process. These artificial Nagura stones are the equivalent of the 8,000 gold stone and therefore there will not be a problem with particle contamination when used on other grit stones. Size: 70 x 20 x 23mm
EAN Barcode | 4963188108509 |
Grit | 8,000 |
