JSP Force™ 8 and Force™ 10 Filters - Pairs
- Force™ 8 and 10 filters for protection against particulates
- Low profile for minimum visual impairment
- Integral maintenance-free inhalation valve
- Easy and secure fit to respirator
- Supplied as packs of two cartridges
- EN14387 A2 Organic Vapour Cartridge: organic vapour class 2
- EN14387 ABEK1 Combination Cartridge: organic/inorganic gases and vapours, class 1
- EN143 P2 Dust Cartridge: medium efficiency dust filter
JSP Force™ 8 Reusable Half Mask - Medium (Without Filters)From £15.78 £13.15
These cost effective filters fit the Force™ 8 and 10 Half-Face Mask for protection against particulates. They have a low profile angle for minimum visual impairment. The cartridges feature an integral maintenance-free, disposable inhalation valve. They are easy to attach to the respirator with a secure fit when applied.
Supplied as packs of two, available cartridges:
A2 Organic Vapour Cartridge: organic vapour and nuisance odours class 2. Designed for use with organic vapour and nuisance odours such as solvent based paint, white spirit. EN14387 A2
ABEK1 Combination Cartridge: organic and inorganic gases and vapours, class 1. Designed for use with organic vapour, inorganic vapours, acidic vapours, ammonia, nuisance odours, solvent based paint, white spirit, chlorine (cleaning and pools), brick acid (graffiti removal), formaldehyde. EN14387 ABEK1
P2 Dust Cartridge: medium efficiency dust filter. Designed for use with fine dusts, mists, water based painting, rubbing down paint with hand tools, glyphosate (weed killer), fibres and fibre glass, hard and soft woods. EN143 P2
