Laguna 18|36 Woodturning Lathe 230V
From £2,815.98 £2,346.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
  • Bowl turning capacity of 450mm diameter over the bed
  • Heavy cast-iron bed ensures maximum stability and minimal vibration
  • Self-ejecting tailstock with long quill travel extends reach and usability
  • Forward and reverse rotation enhances versatility and finish quality
  • Indexing positions at 14, 36, and 48 for precise and repeatable patterns
  • 1.5kW induction motor with a VFD frequency converter
  • Digital speed readout allows for precise control and monitoring of speed
Powerful precision in every turn
From compact versatility to large-scale capability, each Laguna lathe is engineered with precision, power, and user-centric design for an unparalleled turning experience.
Cast-iron beds
Gives strength and low vibration
Belt change lever
Offers quick adjustment
Indexing positions
Improves detail in project designs
Spring-loaded spindle lock
Enhanced safety
Belt change lever
Offers quick adjustment.
Enables speed optimisation for consistent quality
Projected nose cone with dual bearings
Gives additional accuracy and better work access
Axminster Tools Extended 2-Year Warranty
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care.
Find out more
Unlock the full potential of your machine
With the extensive range of Laguna accessories
See the accessories
The Laguna 18|36 Woodturning Lathe is designed with the user in mind to prioritise strength, stability, and control, satisfying both specialists and woodturning professionals. Its robust construction, advanced features and user-friendly design make it an indispensable asset in any workshop. This lathe features a bowl turning capacity of 450mm diameter over the bed and a swing over banjo of 340mm, making it versatile for a wide range of tasks.
The solid bed, with an impressive width of 208mm, is made of high-quality ASTM A36 steel, which is tougher than cast iron. This precisely ground bed ensures smooth travel of the headstock, tailstock, and tool rest, providing stability and reducing vibrations. The headstock, tailstock, and legs are made from heavy cast iron, securing minimum vibration and high comfort for turning oversized pieces.
One of the striking features of the lathe is an ergonomic panel with controls mounted in an anodized aluminium plate. The speed is smoothly controlled with a tactile rubber augmented knurled aluminium dial, and the blue hue of the speed indicator makes this machine stand out from the competition. The easy access rubber grip lever for belt change simplifies and speeds up belt adjustments, while the self-ejecting tailstock, with long quill travel of 114mm, enhances convenience and efficiency during operations. Tailstock and headstock cam lock levers are placed on the back of the machine to avoid interference, and all cam lock levers have soft grip handles and a long length, resulting in a firm feel with no deflection.
The variable speed feature is ideal for delicate work, large diameters, or unbalanced pieces, giving you the control you need for any project. The lathe offers forward and reverse rotation, providing versatility for different turning tasks. The indexing positions at 14, 36, and 48 allow for precise and repeatable positioning. The spring-loaded spindle lock facilitates quick and secure spindle changes, and the hardened steel leading edge tool rest provides durability and stability for tool support.
Powered by a 1.5kW induction motor with a VFD frequency converter, this lathe delivers high torque at low speeds, perfect for demanding tasks. The VFD frequency converter is a key component that enhances the lathe's performance by adjusting the frequency and voltage supplied to the motor. This results in smooth and efficient operation, even at low speeds. The ability to deliver high torque at low speeds is particularly beneficial for demanding tasks, such as turning large or unbalanced pieces of wood. It ensures that the lathe can handle heavy-duty work without compromising on power or stability.
The speed range can be changed with a clever one-lever mechanism, and the digital speed readout offers precise control over spindle speed. The projected nose cone allows for greater work access and wider bearing spacing, enhancing your working experience. The swing-away tailstock provides convenience when working on larger pieces, and the 800mm swing-away bed extension allows for turning longer workpieces. Additionally, the optional mobility kit facilitates easy movement of the lathe around your workshop, making it a versatile and indispensable tool for any woodturner.
Supplied with 2MT four prong drive centre, 2MT revolving tail centre, 75mm (3") diameter faceplate, knock-out bar, onboard storage for accessories, 1.8m power cable with UK 3 pin plug. For serious home workshops and professionals, the Laguna 18|36 Woodturning Lathe is more than just a tool - it's an investment in quality and precision. Elevate your woodturning projects to new heights with the Laguna 18|36 and experience the difference that professional-grade equipment can make.
Axminster Tools offers an optional 2-year extended warranty on all Laguna machines, ensuring peace of mind and comprehensive coverage. This extended warranty must be purchased at the same time as your Laguna machine. Please see the warranty link below for more details.
Warranty Laguna 1 Year Warranty, Axminster Tools Extended 2 Year Available
Laguna Machine Warranty Options
Laguna 1-Year Warranty
The standard 1-year manufacturer's warranty for Laguna machines guarantees satisfactory quality, fitness for purpose, freedom from material defects, and compliance with UK regulations.
Enhance your peace of mind with Axminster Tools' optional 2-year extended warranty on all Laguna machines. This extended warranty, is only available for purchase at the time of purchasing your Laguna machine. It ensures comprehensive coverage for any defects in workmanship, parts, and materials for a full two years from the original invoice date. With this extended warranty, you can rest assured that any faulty part will be repaired or replaced at no cost to you, providing you with the highest level of support and protection on your investment.
Choose Axminster Tools' extended warranty and enjoy the confidence of knowing your Laguna machine is backed by exceptional service and care. Find out more
