Laguna Revo 12|16 Lathe Bed & Banjo Extension
111800
From £173.98 £144.98
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Extends the bed length, allowing you to work on longer pieces with ease
  • Provides additional support and stability for your tool rest
  • Enhances versatility, making it ideal for larger woodworking projects
  • Made from high-quality materials for durability and reliability
Enhance your Laguna Revo 12|16 Lathe with the Bed & Banjo Extension. This accessory extends the bed length, allowing you to work on longer pieces with ease and precision. It's perfect for larger projects like table legs and spindles, saving you time and effort by reducing the need to reposition your work. The additional banjo provides extra support and stability for your tool rest.
Constructed from high-quality materials, the Bed & Banjo Extension is durable and reliable, ensuring stability and reducing vibrations. Installation is straightforward, allowing you to integrate it into your lathe setup quickly. The high-torque motor controller ensures that wood-turners can handle workpieces up to 406 mm (16") without stalling or spindle bogging. The spindle adapter features 1" x 8 TPI threads, accommodating both right-handed and left-handed threaded chucks.
The Expansion Set includes a 254mm (10") bed extension, a cast-iron swing banjo extension for the tool rest, a spindle adapter and all necessary hardware. This extension can be attached at the end of the bed to increase the centre-to-centre capacity by 250mm, resulting in a total turning length of 660mm. Or to the left of the headstock for outboard turning, allowing a maximum diameter of 409mm.
Upgrade your Laguna Revo 12|16 Lathe with the Bed & Banjo Extension for increased capacity, enhanced stability, and greater versatility in your woodworking projects.
