Laguna Revo 12|16 Lathe Bed Extension 500mm
111801
From ÂŁ187.98 ÂŁ156.65
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Adds 500mm of length to the Laguna Revo 12|16 Lathe for larger projects.
  • Provides extra space for working on longer pieces like table legs and spindles.
  • Ensures stability and support for precise, smooth finishes.
  • Easy to install, quickly enhancing your lathe’s capabilities.
The 12|16 Lathe Bed Extension is specifically designed to enhance the capabilities of the Laguna Revo 12|16 Lathe. By adding an extra 500mm of length, this extension allows you to tackle larger projects with greater ease and precision. Whether you’re working on longer pieces like table legs or long spindles, this extension provides the additional space and support needed to achieve high-quality results.
Crafted from high-quality materials, the Bed Extension ensures durability and stability, allowing you to work confidently on your woodturning projects. Its robust construction minimises vibrations, resulting in smoother and more accurate cuts.
The extension seamlessly integrates with your existing lathe setup, maintaining the same level of performance and functionality. It features a straightforward installation process, so you can quickly and easily attach it to your lathe and get back to work. The ergonomic design ensures that the extension does not compromise the comfort and ease of use of your lathe, making it a valuable addition.
With the Revo 12|16 Lathe Bed Extension 500mm, you can expand your creative possibilities and take on more ambitious projects. Whether you're a professional woodworker or a passionate hobbyist, this extension will help you achieve outstanding results and elevate your woodworking experience.
